4 members (baldeagle, Joe H, Bill Hanlon, Jon G), 120 guests, and 4 robots.
Topics128,014
Posts1,055,333
Members48,419
#1221512 06/15/2017 7:03 PM
Hello, am new to the site but not new to vintage vehicles, good to be here for the valuable info.
I was wanting to replace cab mounts on my 54 3100 and wondered how to support the cab while doing this without crushing any body panels.
Red dot, center of chest ...
The cab is supported by five rubber mounts. You can lift the cab with a hoist and replace them, or get some friends to help you remove it and set it on the floor. If you use a hoist, make sure you put something between the chains and the metal.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
If you do one at a time, you can use a long pry bar to lift up a corner at a time and place a spacer between the cab floor and the frame or front cab support to give you room to put in the new rubber mount pieces. You won't hurt a thing.
Thanks for the help
Or like Carl said if you do them one at a time, use a hydraulic bottle jack with a piece of 2x4 or the like to spread out the weight and take pressure off when you unbolt the shackles on the rear and for when you unbolt the fronts
If the corners are lifted one at a time, can the metal be replaced at the time if necessary?
The front cab mount supports can be replaced one side at a time that way.
I do not like to do one corner at a time, unless I can "settle"/set/support the cab such that I know nothing can be twisted (as might happen from lifting one side higher than the other).
Welcome to the club, Posey! And thanks for asking that question, because my '51 has started squeaking on the front left recently, and I think I'm looking at the same job. And thanks for the answers, guys!
"When I rest, I rust"
1951 3100 5 window w/ '56 235
If a cab is so far gone that lifting one corner 1/4" higher than normal to replace a mount would compromise the integrity of the entire cab, then it would indeed not be a good idea to do so. If the cab is that bad, it would be a better choice to look for another cab entirely.
If you loosen both front cab bolts, the rear cab mounts design (either dual shackles, or center pivot mount) will allow a relatively large amount of lifting of the front mounts without torquing the cab at all.
Carl
