3 members (Hotrod Lincoln, 2-Ton, 1 invisible),
63
Mod | | | Forums66 Topics128,021 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | Hello, am new to the site but not new to vintage vehicles, good to be here for the valuable info.
I was wanting to replace cab mounts on my 54 3100 and wondered how to support the cab while doing this without crushing any body panels.
Thanks | | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | The cab is supported by five rubber mounts. You can lift the cab with a hoist and replace them, or get some friends to help you remove it and set it on the floor. If you use a hoist, make sure you put something between the chains and the metal. | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | If you do one at a time, you can use a long pry bar to lift up a corner at a time and place a spacer between the cab floor and the frame or front cab support to give you room to put in the new rubber mount pieces. You won't hurt a thing.
| | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | | | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | Or like Carl said if you do them one at a time, use a hydraulic bottle jack with a piece of 2x4 or the like to spread out the weight and take pressure off when you unbolt the shackles on the rear and for when you unbolt the fronts | | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | If the corners are lifted one at a time, can the metal be replaced at the time if necessary? | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | If the corners are lifted one at a time, can the metal be replaced at the time if necessary? The front cab mount supports can be replaced one side at a time that way.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I do not like to do one corner at a time, unless I can "settle"/set/support the cab such that I know nothing can be twisted (as might happen from lifting one side higher than the other). | | | | | Joined: Nov 2014 Posts: 623 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 623 | Welcome to the club, Posey! And thanks for asking that question, because my '51 has started squeaking on the front left recently, and I think I'm looking at the same job. And thanks for the answers, guys!
"When I rest, I rust" 1951 3100 5 window w/ '56 235
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | If a cab is so far gone that lifting one corner 1/4" higher than normal to replace a mount would compromise the integrity of the entire cab, then it would indeed not be a good idea to do so. If the cab is that bad, it would be a better choice to look for another cab entirely. If you loosen both front cab bolts, the rear cab mounts design (either dual shackles, or center pivot mount) will allow a relatively large amount of lifting of the front mounts without torquing the cab at all. Carl
