| | | Forums66 Topics128,043 Posts1,055,609 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | How often do you guys repack your front wheel bearings? Do you have a favorite grease? Is it necessary to replace the inner seal or can the old one be reused if it is in still in good condition?
I know these are basic questions, but It's always good to know what you are getting into before things get torn apart.
Thanks George | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I do them whenever I do brake work or any service that requires removeing the drums. If they are packed & adjusted correctly they will go several years before needing attention again. I use a good brand of Lithium grease that is recomended for disc brakes. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,763 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,763 | Ditto on the DB rated bearing grease. It stays put at much higher temperatures than chassis grease, and brakes generate a bunch of heat. Seals are inexpensive enough that I'm not a fan of reusing one. Why take a chance of ruining a hub or a spindle, or soaking a set of brakes if there's a leak? Jerry
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | | | |
