3 members (JW51, UtahYork, Wickedbass), 61 guests, and 2 robots.
Topics128,066
Posts1,055,876
Members48,428
Page 2 of 2 1 2
Originally Posted by panic
Also shows a different collar, but only for the exhaust?
Some Chevy V8 exhausts have a positive rotator built into the spring retainer, resulting in needing about a 3/16" shorter exhaust valve spring. Not sure if the same assembly was used on the stovebolt engine?
46er #1222335 06/22/2017 11:41 PM
46er (Gerry) I tried to send you a private message but I think you're too new for you to receive one. Make a few more posts. - Rusty
It's a small world, but I wouldn't want to paint it.
Joe H #1222340 06/23/2017 12:04 AM
You might want to check out vintage speed. He makes a lot of different setups with progressive linkage. He made me 3 Roch. 2 bbls that mount right onto the blower on my 292. He makes a setup that is a little manifold that will bolt to the Clifford 4 bbl. manifold.
There are quite a few motorcycle carbs that are the right size to use 3 X 1 (make your own manifold) but remember they all use gravity feed and have very large needle & seat assemblies. For some, a smaller seat (for a fuel pump) may be bought or converted but they will run super rich as-is.
Page 2 of 2 1 2
