7 members (Phoneman, wilbur53, 1955 1 Series, SmalltownTRKGuy, Jon G, ShopRag, Southerntruck),
140
Mod | | | Forums66 Topics128,209 Posts1,057,461 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | Hello Everyone, I've noticed the trend lately for 47-53 Chevy trucks is to use white walls. While I have no problem with this, I would like to use black wall tires either radial or bias ply. What company can I trust? | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Like you, I want to put radials on original 1939 15" artillery rims. My current bias ply tires are 7.00 x 15. American Classic carries radial black walls that look like bias ply. Lucas, Coker and others carry American Classic. They are expensive. Have any of you folks used American Classic?
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I have used Cooper and Goodyear blackwall 16" LT radial tires, with and without tubes on 4.5" rim-width original wheels. | | | | | Joined: Nov 1995 Posts: 5,747 24601 | | 24601 Joined: Nov 1995 Posts: 5,747 | Rick,
Still awaiting confirmation but it appears American Classic has been sold to Classic Parts.
V/R John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | You can find 285/85R15 black walls many places for about $75 each. This is a close match to the original tire size.
Evan
| | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | But what company can I trust? For example, I've heard and read that Coker Tire Company has given folks quite a few problems with poor quality tires....? What are some other companies that I could shop from that y'all know of? | | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | Just looked at the Lucas Tire website - WOW, nice looking tires BUT very expensive! Almost double the price.... :( | | | | | Joined: May 2015 Posts: 11,188 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,188 | You can find 285/85R15 black walls many places for about $75 each. This is a close match to the original tire size. I think you need to double-check that size, 285mm is over 11 inches wide (compared to ~7-1/4 inches for a 7.00x15 tire). A 7 inch wide tire would be around 185 mm. I run LT265/75R16's on my F250 and they're definitely not pizza cutters. They'd look almost comical on an AD. To the OP, Go to TireRack.com and browse the sizes available, If you look at the specs for a tire, it will tell you the diameter and overall width. Here's the specs for a 700-15: Diameter 29.18 Tread Width 5.38 Overall Width 7.35 Revolutions per mile 691. Here's their listing of all 15 inch tires.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | check with local tire shops where you can go back and bang on the counter if there's a problem here's a size conversion list, 235/65R15 is the nearest equivalent to 700-15 Bill | | | | | Joined: May 2015 Posts: 11,188 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,188 | check with local tire shops where you can go back and bang on the counter if there's a problem  I wasn't necessarily advising to buy from Tire Rack, but they are a good resource for info. The best time to bang on the counter is to wait till the shop is full of customers. They tend to give in quicker to shut you up.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | I appreciate the info guys, but some how this thread became about 15 inch tires. I'm trying to locate 16 inch tires (6.00) black walls to give my 49 Chevy Panel the authentic look - in either a radial or bias ply? I heard of Coker which would have been my first choice until I read some threads on Stovebolt that people have had bad luck with Coker tire. So I'm asking what other companies out there do y'all trust and deal with? | | | | | Joined: May 2015 Posts: 11,188 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,188 | Sorry, we got sidetracked by the reply about 700-15 tires.
I just checked Summit Racing and they carry a couple of Kelsey brand tires in 600-16 as well as a bunch of Coker tires. I have no experience with either brand though. Sorry.
