3 members (Otto Skorzeny, moparguy, DaveV), 112 guests, and 1 robot.
Topics128,111
Posts1,056,244
Members48,437
#1220876 06/10/2017 10:58 PM
I've got a '48 low pressure 216 in my truck. Runs fine, but I'm getting blue smoke under harder acceleration, but only when the engine is warm. At idle it's clear. When it is cool or warming up, no smoke either. I did a compression test. Results as follows: 1-111, 2-110, 3-90, 4-110, 5-107, 6-100. Not horrible, but not great either. I haven't noticed any big blow by. Wondering if it's just valve seals. Thoughts?
How much oil is it using? A little smoke is no big deal, as long as it's not using a lot of oil or losing power. It's just showing its age a little. Oil is a lot cheaper than engine parts, especially on a 216. Leaky valve seals tend to blow a little blue smoke on a cold start, and/or you'll get a puff of smoke after coasting for a distance and getting back on the throttle. Your symptoms sound a lot more like the piston rings are getting a little tired.
Thanks for the feedback. It's not burning a lot of oil, and it's not getting dirty too quickly, which I'd expect if there was a lot of blow by. Obviously a ring/piston job is a big deal. Is there a way to test if the valve seals are contributing without ripping it all apart? Valve seals are dirt cheap, and it's just my time to do it.
Go ahead and change the valve seals- - - - -it won't make any difference, but if it makes you feel better, do it.
Crusing in the Passing Lane
When you do your next compression test, squirt some oil in the spark plug hole, if the compression gets better, rings; often can hear valves leaking by listening in manifold.
Ed
Do a cylinder leakdown test to confirm where the pressure loss is going.
Hint: It's the piston rings!
Ed
Suspect his oil burning (smoking) ...........his rings are already sealed with excessive oil. If the oil was not the there the true compression would be far less than the 100-110 PSI previously meausred. Cylinder leak down test is the preferred test........ as mentioned.
