3 members (Otto Skorzeny, dwreills, Peggy M), 56 guests, and 2 robots.
Topics128,035
Posts1,055,446
Members48,422
#1220880 06/10/2017 11:25 PM
I just took the side windows apart, found a felt seal between the glass and frame. is this correct or did some previous owner add this. is there supposed to be some setting tape in there, if so, what thickness? thanks, don
There is a felt channel the front and rear of the glass rides in. There is also a rubber seal along the outside top edge of the window opening. Right where you could rest your arm if the window were open
yes, I understand the channel at the front and rear, the window has a frame around the glass, and between the frame and glass there is a felt seal. should that be there or should it be glass setting tape?
Oh you are asking about the glass frame. The bottom channel uses glass setting tape. Not sure around the other 3 sides. Felt might have been OEM? Felt will wick water. I did all mine by spacing with small pieces of setting tape then sealed by a small bead of urethane window sealant. You need some type of material to center the glass.
