| | | Forums66 Topics128,192 Posts1,057,350 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | I just took the side windows apart, found a felt seal between the glass and frame. is this correct or did some previous owner add this. is there supposed to be some setting tape in there, if so, what thickness? thanks, don | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | There is a felt channel the front and rear of the glass rides in. There is also a rubber seal along the outside top edge of the window opening. Right where you could rest your arm if the window were open | | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | yes, I understand the channel at the front and rear, the window has a frame around the glass, and between the frame and glass there is a felt seal. should that be there or should it be glass setting tape? | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Oh you are asking about the glass frame. The bottom channel uses glass setting tape. Not sure around the other 3 sides. Felt might have been OEM? Felt will wick water. I did all mine by spacing with small pieces of setting tape then sealed by a small bead of urethane window sealant. You need some type of material to center the glass. | | |
