I recently replaced my drivers side outer cowl and rear cab corner. And I also replaced the passenger side outer cowl. I used a level to square up the panels and didn't think to measure the original door gap. Well, I got myself into a pickle. I welded everything up and to check myself I set the door in place and I have some serious door gap issues.
Please take a look and help me decided what might be the best solution. I seriously do not want to cut these panels out and re-replace them so any advice is welcome. One more note: I just placed the door in position I don't have the hinges in yet. Should I put the hinges on before I really start to have a panic attack??
http://picasaweb.google.com/akuips/PanelReplacementPictures Thanks in advance for your advice!
