6 members (Hotrod Lincoln, klhansen, Mike B, Otto Skorzeny, IHPWR, Jims46), 50 guests, and 2 robots.
Topics128,030
Posts1,055,423
Members48,422
#1219390 05/30/2017 10:39 PM
been looking for a starter rod for a stomp starter, wonder if someone could help with the length, mine is a 7/16-20 thread, if I had the length and how much thread is on the button side I'd make one out of a bolt It's for a 49 1/2 ton, don't have the engine in yet. Just looking ahead.....Thanks
Well, if Denny Graham would poke his head out of the Greasy Spoon every once in a while he would give you the exact specs on that part. You might be able to search under "Denny starter pedal" and find his post on the matter.
I might have one you can have. Let me look tomorrow.
' Offline
1954 3600
Now cruising in
The Passing Lane
yes that's the rod '54 3600, thanks Roy Rogers be more that happy to pay for it and the postage.. Thanks all
Well.... try as I might, I haven't found it yet. Found other stuff I forgot I had. Like the two front studs used on the engine mounts on 58 six cylinder engines.
It's 7/16 fine thread on each end of the rod so it might not be hard to make up with a piece of rod and a thread dye.
I'll be back in the shop Friday and will dig around some more.
I have one, it's just finding it. (I'm a hoarder) Shhhhhh
