| | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 79 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 79 | been looking for a starter rod for a stomp starter, wonder if someone could help with the length, mine is a 7/16-20 thread, if I had the length and how much thread is on the button side I'd make one out of a bolt It's for a 49 1/2 ton, don't have the engine in yet. Just looking ahead.....Thanks | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Well, if Denny Graham would poke his head out of the Greasy Spoon every once in a while he would give you the exact specs on that part. You might be able to search under "Denny starter pedal" and find his post on the matter.
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I might have one you can have. Let me look tomorrow. | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 |
| | | | | Joined: Dec 2007 Posts: 79 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 79 | yes that's the rod '54 3600, thanks Roy Rogers be more that happy to pay for it and the postage.. Thanks all | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Well.... try as I might, I haven't found it yet. Found other stuff I forgot I had. Like the two front studs used on the engine mounts on 58 six cylinder engines.
It's 7/16 fine thread on each end of the rod so it might not be hard to make up with a piece of rod and a thread dye.
I'll be back in the shop Friday and will dig around some more.
I have one, it's just finding it. (I'm a hoarder) Shhhhhh
