0 members (),
162
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2017 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2017 Posts: 43 | Trying to ID the torque tube type 3 speed in my 40 3/4 ton Chevy. It's 11.5 inches long. Casting #'s 591195...GM4...42...4227. Some of the casting #'s are hard to see so I may not have them exactly right. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | 591195 is a 1941-47 truck 3-speed... Mike B  | | | | | Joined: Feb 2017 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2017 Posts: 43 | Thanks Mike! I'm trying to switch to open drivetrain. Do you know if there is a trans that uses the same bolt pattern and is open driveline? | | |
