2 members (MickeyP, Charles in CA), 38 guests, and 9 robots.
Topics128,012
Posts1,055,311
Members48,419
#1219678 06/01/2017 10:23 PM
Installed a new speedometer cable and during test drive needle did not go beyond 20mph.Thoughts? Thanks, Scott
scottss60 #1219687 06/02/2017 12:28 AM
Check that the drive cable is fully inserted in the tranny and speedo head
Ed
scottss60 #1219693 06/02/2017 1:46 AM
I agree with Ed. But if that doesn't work, did you check the speedo for freedom of movement?
The speedo I pulled out of my truck two weeks ago was pretty much seized. I had to take it apart, clean it and lube it to get it turning freely again. See if you can spin the little brass collar on the back (right where the speedo cable goes in).
~ Dave
scottss60 #1219694 06/02/2017 1:50 AM
What year truck are we talking about?
Have you replaced any of the other gauges with new ones?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
scottss60 #1219717 06/02/2017 5:07 AM
53 1/2 ton. Will follow advice when return after two weeks away. Thanks.
scottss60 #1219811 06/03/2017 1:00 AM
Check to see if the odometer is working correctly. If it is, you probably have a problem where the inner cable is applying pressure on the inner shaft. I have observed this playing with spares on the bench. It also may have something to do with worn bearings or bushings inside.
1951 1 Ton Completed
