3 members (Ponchogl, wilbur53, Otto Skorzeny), 99 guests, and 0 robots.
Topics128,113
Posts1,056,616
Members48,450
Junior Member
Junior Member
Been reading/learning a lot about prepping and painting. I picked up a 5 liter 2K clear and MSB thinner. Based on what I've read this is a good clear. My question is what is the mixing ratio? I don't see that on the can plus I'll be using a 1.4 HPLV gun when spraying is this good enough?
I used Standox primer, basecoat and clearcoat and was happy with the results. Here's a link to the tech page which will have all your answers.
http://pc.dupont.com/bowstreet5/webengine/dpc/common/Controller/Action!_pageDispatcher/InnerModel!dpc/modules/Login/OuterModel!dpc/common/Controller/InnerAction!visitorAction
Curt B.
You Tube
Junior Member
Junior Member
Now I have all the info needed to use this clear on my truck but can I use the Thinner, is this considered as a reducer?
