| | | Forums66 Topics128,128 Posts1,056,685 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 32 | Hey guys! Quick question. I have a new rear window gasket on the way from Steele. What is the process to install the rear window? Do you put the gasket around the glass, and use the cord method to set the gasket over the body?
Or do you install the gasket first on the cab, and press the window in place? Thank you!!!!!!! | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 |
Harold Is a restoration ever finished? | | | | | Joined: Nov 2010 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 32 | Got my gasket and just spent 4 hours trying to get the darn glass in with no luck. What a pain in the butt!!!!!!!!!!!!!!!!!!!!!!!!!!!!! | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | paintman,here's a direct link to the pictorial guide I did some time ago,this is on an AD cab but the technique remains the same,I hope this helps. Rear window installation using Claytonrite style seal.If you click on the individual pictures there's a description too.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
