| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | I have had my bench seat and back out for a while as I worked under the dash. Putting them back in is not as easy as I thought. Is it best to put the bench in first then the back or the opposite? Thanks, Scott | | | | | Joined: Sep 2013 Posts: 1,361 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,361 | Back first, when you put the seat bottom, in I find it best to set on it so I can use my legs and weight to slide it back into position.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | | | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | Mine is easier putting the seat then the backrest Was very hard in dec 2016 when it was new | | |
