2 members (RLB, carbking),
68
Mod | | | Forums66 Topics128,105 Posts1,056,541 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | I'm working on my 41 3/4 ton with the objective of getting it running and stopping on it's own....before the end of June. Put a 350/700r4 and went to a one-piece driveshaft. I know the 350 is good and I had the 700r4 rebuilt. Now I'm on the the brakes.
The front axle and rear were changed out by PO to 55-59. With the help of 3B, the rear axle was determined to be HO52. I went looking for 12" brakes for it and found them difficult to come by...as well as other parts. So, after researching, determined it would be better to go with a 14 bolt, as recommended by Grigg and others.
So, I would appreciated some help from you guys to search for the 14 bolt I need.
I understand I need one from a C&C because the wms-wms width is 63.5". I read there was a difference between the 72-88 and 89+ yrs., but don't know what.
What years C&C will work? Are they in the P20's and P30's? I understand I will need to relocate the spring perches. I put a drum/drum power brake system on with 1-1/4 bore master cylinder. Will that be OK with the 14 bolt rear? Will I need to change the U joints or will they match up from the HO52?
Anything else I need to be aware of???
As always, thanks for your help.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | I just put a 14 bolt srw from a mid 70's 3/4 ton pickup in my 46 3/4 ton. I only had to change the axle shock mount locations and add a mount on the frame. You may find a C&C spring perches are too narrow for the stock 41 3/4 ton spring location. I went dually on an SRW but singles may require a spacer for better fender fitment. http://67-72chevytrucks.com/vboard/showthread.php?t=721028
| | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | Thanks for the link to your thread. Very helpful!
Why did you go with a SRW and then change out to longer bolts for dually's rather than going with a C&C to begin with?
I plan on going dually...have 19.5" 8 lug to go on it.
Also, what is your the gear ratio in yours?
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | On a C&C for a dually the spring perches could not be moved out enough on the axle to fit it on the 46 3/4 ton springs -- which defied moving. I wanted to keep it as tight as possible for the duallies and I wanted to keep the inside dual outboard of the step bed sides. The c20 axle was perfect. I have the fenders and will build 10 inch spacers out of 14 gauge. But this axle would easily work for a single and depending on wheel back spacing may need a spacer to place correctly under the rear fender.
3.73 gear-- did not have gov loc --- was ok either way. 216 with 4 speed --used the stock 3/4 ton mc.
I am not saying a van or van cab/box srw would not work but the c20 did not require even moving the perches.
I did my best to align the duals on the srw but I do run less air on the outside duals than the insides. I am not worried about tire heat on a truck running 45-50 mph for 20 miles hauling a lawn chair. 8-)
| | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | My HO52 WMS-WMS is 62". The C&C dually is 63.5" I measure 44" to the outside of my springs (2" springs, so 42" o.c.) with another 5" on each side to the backing plate.
I thought I read somewhere the spring perches on a C&C 3/4 ton was 42.5" and 40.5" for one ton. Either one would not require moving the perches more than 1" on each side.
I put my duals (8.5 x 19.5) on my HO52 and outside the tires measures 80". If a C&C fits, that will become approx. 82".
I think we have the same goal: to keep it as tight as possible. I have rear fenders too (that need work) but was hoping not to add 10" to them.
What am I missing? Thanks again for your advise...much appreciated.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | I looked at an 81 or so C30 8 lug drw c&C and measured but could not move the axle perches out far enough to mount to the 46 3/4 ton springs without the backing plates interfering so I may be mistaken and there is another 14 bolt that fits better. I was looking at a bare chassis taking measurements from the top. | | | | | Joined: Jun 2005 Posts: 1,002 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,002 | Understood.
When I began researching a week or so ago, one of the first things I read was that there a many different types of 14 bolts, with various specs. They said make sure you know what you are looking for.
That's why I was being such a PITA by asking you all of those questions. You have been very helpful and I thank you for that.
BTW, your truck looks great!!
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | Hey VFW, thanks for the compliment and good luck on your truck. Your questions were good and genuine. I use the web a lot and there are a couple guys at the cruisins that know a lot. Then I build something off the wall sometimes. Then my 83 year old uncle changes his mind on direction. I admit there is a lot I do not know just ask my wife.
When I get in the mood I have 2 doors ready to paint then other pieces plus bed and I have a nice 216 that I resealed and painting to put in the 46 replacing the 235 for something else.
But today I am taking the 67 k10 to a car and tractor show in Lynchburg, OH.
