7 members (Shaffer's1950, Donf, JoeDude, 48jim1ton, gswbbc, frogfarmer, Gdads51),
120
Mod | | | Forums66 Topics128,032 Posts1,055,516 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | I'm having some trouble timing my 235, I pulled the distributor to clean/ check the spring and rub washer. My son was helping me put it back in and decided it was easier to back off the clamp and install the bracket, then the distributor. I don't think its indexed correctly, so I'm checking from square one. My question is if the points should be open or closed at TDC? My senior moment tells me no then I think yes. Hate it when I can't remember info I haven't used for years! Thanks John | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | check the thread on knocking after a new vacuum advance.
Static time using the pointer on the bell housing and the BB in the flywheel. #1 cylinder on compression stroke. The light should just come on. I use a home made T-handle crank to turn the engine over.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Thanks Mike. That's what I thought. John | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The points should be just starting to open. | | |
