| | | Forums66 Topics128,118 Posts1,056,302 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 47 | I am rewiring my 52 - 3100 and will be mounting new terminal boards on inner fenders. I need the solid rivets, two per board, and some tips how to install them. I have found rivets online but have to buy hundreds? I went to home deport and tractor supply no luck. Help. Thanks, Denis
Thanks Denis Used to drive Subs, prefer old rides
1952 chevy 3100, 5 window
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Hollow rivets would be easier for you to set. Bag of 100 on line will cost as much as a plastic package of 6 at a hardware store.
| | | | | Joined: Dec 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 47 | Jim thanks and I have tried that with no luck. Denis
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | What size are you looking for? I buy these by the pound in 3/16 and 1/4. https://www.imperialsupplies.com/item/0730490?searchOverlayTerm=buck%20riveetsIf you are close to a trailer repair shop, they have them. If bad goes to worse, I can send you some, but they will have to go parcel post because a letter can't be over 1/4" thick. | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | You can make rivets out of small carriage bolts. I did that to make replacement rivets for the rear fenders. I had to reshape the heads to match the originals by putting them in a cordless drill and dressed them into shape on a bench grinder, then polished them on 400 grit sandpaper while still in the drill. I didn't set them like rivets. I just used a nut and lock washer underneath where no one will see them. Carl
| | | | | Joined: May 2015 Posts: 11,070 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,070 | McMaster Carr (onolne shop) has steel solid rivets. They sell in large quantities but are relatively cheap. I recall riveting sheet metal in my dad's shop. He used just a few sizes and used a rivet set for use with a hammer. The rivet was put in the hole in the metal to be fastened, bucked (backed up)with a heavy piece of steel, hit once with the set to upset it, then the set was moved to put the rivet into the hole in the set and hit again to push the two pieces of metal together, then back to the heading portion and hit a few times to form a head on it. FWIW, the original rivets holding the rear fender crown brace to the fender were steel tubular style, but finding tubular rivets short enough and with the low domed head to match the originals is tough to do. I'm pretty sure it's spelled "despot".
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | By the time you upset a solid rivet, on opposite sides of a fender, you will destroy the terminal boards and dent the fender. You have to buck one side and smash the other. Not to be used in phenolic or plastic or fiber board material. Even a pop rivet may smash too hard and bust the board. You got your tubular rivets too, which they probably used because pop rivets weren't used back then on automobiles. Use a solid rivet with a tinnerman on the backside. (no smashing) There are various styles of Push nuts. The upper left one is for straight shafts (like a rivet shank). Push it on the rivet shank, on back side of fender, with a small socket. It will give you the look and retain the board. For fender moldingLowes and many places have rivets. Don't look at the quantity of this stuff look at the price. You can't buy four nails either.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2010 Posts: 2,315 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,315 | There are also closed end rivets that are available ,you use a pop rivet gun and the one side is the same as a open rivet but the othere end is solid . I used these for a aluminum boat as they are solid and don't leak.if it is the look you are looking for they may be okay if you put them in from the opposite side . | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | That would possibly be ugly. I don't recommend pops for his terminal boards if they are non metallic. Don't know what they are yet.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Or...set a Rivnut and bolt it down. | | | | | Joined: May 2015 Posts: 11,070 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,070 | Another option for the terminal board that would maintain the original look would be split rivets. Should be fine for holding the terminal board on.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 47 | Thanks everyone, not sure which approach I will take. Denis
