1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 16 New Guy | | New Guy Joined: Mar 2017 Posts: 16 | Hey Gang, First I would like to say God Bless to all our Vets today. I have my frame almost done with my new shackles coming in next week I will be moving on to starting on the engine build. I have two 248 engines, one had a cracked block but ran and one was locked up from sitting. I broke the locked up engine free, had to beat the pistons out with a oak log and sledge hammer, then took it all apart. I took the block to a local machine shop and had it cleaned and magnafluxed. The block has one cylinder that will need to be re-sleeved but otherwise is good to go. My plan is to use all the parts from the running engine in the rebuild, if they are all in good shape. I have no plans to trick out the engine just get it back to original. I will of course put in new rings, bearings and do a head job. I have found it hard to locate the front center rubber engine mount for my engine and year, 1955 2nd GMC, everything I've seen has been a two hole mount not one. One last thing before I start getting the steaks ready for the grill, this is a budget build, I had to do side jobs just for the block work so if the head needs a valve job I'll be doing it. Sorry for being so long winded it's my second cup of coffee. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I have used neoprene grader blade material for snowplows, comes 1" thick by 4" wide by length, works well, not sure they would have it in GA, though.
Ed
