| | | Forums66 Topics128,093 Posts1,056,475 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | http://67-72chevytrucks.com/vboard/showthread.php?t=7387551) Will I need to unbolt every rod, remove timing gear cover and remove the crank to remove/replace the upper crank rope seal or can I just remove the main caps and slightly lift the crank to remove/replace/seat?
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Just loosen the crankshaft main bearings enough and pull up the crank slightly to replace the seal. It will be convenient to do this when the front pulley is off because the seal will not be in the way. However you need to be careful not to change the engagement of the two timing gears. If it were mine I would probably remove the front cover and maybe install a new timing gear. | | |
