4 members (CuzzFuzz, baldeagle, Ponchogl, Stovebolt48), 68 guests, and 6 robots.
Topics128,021
Posts1,055,346
Members48,420
#1218767 05/26/2017 1:34 PM
I'm just curious if anyone has found a way to adjust the starter engaging lever left or right? My pedal is rubbing on the side of the hole in the floor and needs to move (even slightly) I have changed the cab mounts and all the other pedals seem to line up pretty good, just the starter that doesn't.
Thanks!
1948 Chevy Thriftmaster 3/4-Ton
Poncho "farming" in Ontario
Starting in the DITY
Continuing in the Project Journals
More images
There are only 10 types of people in this world, those who can read binary and those who can't.
I wonder if you have a problem with the engine mounts?
My Blog
Geez, I hope not! Anything in particular to look for?
More images
Crap, I think you may be right Dave. I just took these pics and there's a bar of some sort wedged between the motor and cross member. On the side that would move the starter pedal to where it is.
https://goo.gl/photos/yccNmW2YLHnEsRnR6
https://goo.gl/photos/HZM31TC3PLNDpZy49
Any tips on replacing mounts? How difficult is it?
More images
Wow, is that a broken crossmember or is the photo messing with my already poor eyes?🛠
I believe you're looking at some dripped black paint on the cross-member... so it's not you. smile
More images
Goach2 #1218816 05/26/2017 10:05 PM
Whew!!!!
Good call Dave!
(He's a genius, who doesn't bloviate.)
So, after finding this issue with the passenger side mount, I called up my local old-truck parts place and told them I needed a couple mounts and new bolts. He asked me if it was a 5/8 or 11/16 bolt. So I went out to take a look. I crawled under, but the passenger side was so caked-up that I decided to look at the driver's side instead, since it was fairly clean. I tried getting a socked down into it, but something seemed to be in the way. I reach my fingers into it and pull out... a motor mount bolt that was sitting in the mount cup! Then I noticed another piece of steel wedged between the engine and cross-member on this side as well! Using a mirror I looked down into the mount and sure enough, there are two empty bolt-holes on the driver's side. Basically, there is not much holding this engine even in the truck itself!
Is this something they would do for say a farm truck that didn't really leave the property? What are the chances that the mounting holes in the bell-housing are going to be messed up and unable to take a new bolt!
More images
Might want to check the rivets on your rear engine support while you're down there looking at it... all 4 mounting ears on my support crossmember were broken off...
Broken Rear Engine Support
~ Dave
Funny you mention that, I am missing one rivet in that cross-member. Did you re-rivet? Or if you put a bolt in, do you recall what size it was?
More images
I ended up buying some precision shoulder bolts and shim washers from McMaster, reaming the holes to match the bolts, then shimming for a good, torqued fit. They were a nice, tight fit. Hopefully the repair will last.
Donor crossmember installed with shoulder bolts
~ Dave
I used bolts with a 1/2" Diameter shoulder, 3/8" diameter thread, and reamed the holes to size with a 1/2" hand ream after drilling the holes to the size just under 1/2". If you're interested in re-riveting, Deve's Technet has a whole picture show with him re-riveting a crossmember.
~ Dave
Just to circle-back on this post, here's the progress that I've made;
This past Friday my helper came by (my father) and we pulled the mount off the passenger side of the bell-housing. Once the bolt to the cross-member was removed, it was evident that the portion that bolts to the bell-housing had snapped off:
https://goo.gl/photos/thAxkmXPy8AZhUSA8
We removed it, cleaned it up but could not get the mount back on, because of the engine listing to that side. So we went after the driver-side mount next. After removing the bolt through the cross-member, the mount fell off. The bottom bell-housing bolt was long gone and the top one... snapped off inside. After freaking out a little I managed to back it out with a reverse thread drill bit. Luck for me, it was only dirty and not corroded. We mounted up that side and a slight tug got the bolt to drop into the cross-member.
Back to the passenger side, with a little more jack under the oil pan, we were able to get the mount secured to the bell-housing. The hole through that cross-member was pretty far off and I had my doubts that it could be maneuvered into it. A little (or a lot) of work with a long 2x4 and sure enough, it dropped in as well.
After all this, a quick test drive did seem to show it shifting a little easier, although it still needs some carb work and likely timing as well.
Back in the cab, I was able to finally slip the rubber bellows fully onto the starter pedal, which was what started this whole thread. I was surprised that it didn't move more into the middle of the toe board hole, but I'll take it. smile
More images
