| | | Forums66 Topics128,140 Posts1,056,774 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 57 'Bolter | | 'Bolter Joined: Mar 2015 Posts: 57 | i would like to put disc brakes on the stock axle and end with 5x41/2 bolt pattern. any body out there done this | | | | | Joined: Feb 2004 Posts: 11 New Guy | | New Guy Joined: Feb 2004 Posts: 11 | I bought the disk brake kit from Speedway Motors. It was pretty easy but the instructions sucked. I would do it again. | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | The only thing I didn't like about the kit was that there were no dust shields engineered for it. I would have paid extra for those.
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Mar 2015 Posts: 57 'Bolter | | 'Bolter Joined: Mar 2015 Posts: 57 | thanks for the info ill ck them out | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | I am looking at the kit from Performance online.
But "classic industries" and "classic parts" and others have kits as well.
| | | | | Joined: Mar 2015 Posts: 57 'Bolter | | 'Bolter Joined: Mar 2015 Posts: 57 | i want to thank everyone for there words of wisdom i havent found one with 4.5 bolt pattern , as the camaro rear end that i have and unfortuntly i have 2 sets of rims with 5x4.5 bolt patterns so on to the next problem again thank you | | | | | Joined: Mar 2015 Posts: 57 'Bolter | | 'Bolter Joined: Mar 2015 Posts: 57 | i want to thank everyone for there words of wisdom i havent found one with 4.5 bolt pattern , as the camaro rear end that i have and unfortuntly i have 2 sets of rims with 5x4.5 bolt patterns so on to the next problem again thank you | | | | | Joined: Mar 2015 Posts: 57 'Bolter | | 'Bolter Joined: Mar 2015 Posts: 57 | | | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | The Camaro and most other GM passenger car bolt pattern is 4 3/4". Ford and Mopar cars used a 4 1/2" bolt pattern. Many aftermarket wheels are stamped both bolt patterns. Fred
| | | | | Joined: Jan 2013 Posts: 2,236 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,236 | Be careful! I purchased from classic parts (I think) and the brackets that hold calipers in place were incorrectly made. When I tightened the bolts it twisted the calipers so the brakes would not allow wheels to turn.
Chris | | | | | Joined: Apr 2016 Posts: 1,050 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,050 | I think wilwood just started making a kit for them.
