| | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 13 New Guy | | New Guy Joined: Dec 2010 Posts: 13 | I have just begun to swap the 216 in my 52 Styleline for a rebuilt, solid lifter 235 from a '54 truck. I've read about swapping the flywheel and bellhousing from the 216 over to the 235 because later 12v starters and flywheels won't work with a 6 volt starter. I have converted my car over to 12 volts but have still been running the 6 volt starter. If I swap over to a 12 volt starter during the swap does that eliminate the need of swapping over the flywheel and bellhousing from the 216?
Thanks | | | | | Joined: Apr 2011 Posts: 3 New Guy | | New Guy Joined: Apr 2011 Posts: 3 | 6 volt starter, 6 volt flywheel; 12 volt starter, 12 volt flywheel. tooth count is different between 6 and 12 volt starter and flywheel. i don't think bell housing really matters unless it won't match frame mounts.....al | | | | | Joined: Sep 2011 Posts: 1,459 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,459 |
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | As long as you are using a 12 volt flywheel with the 12 volt starter. You will still need to use the 52 bellhousing.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Your 54 truck engine will still have a flywheel for a 6 volt starter. It should have 139 teeth on the ring gear. It will work just fine with the starter you're using currently. If you attempt to pair it up with a 12 volt starter, it WILL NOT work unless you also use a flywheel from an engine with a 12 volt system. That's 1955-up on the cars, or a 55 2nd. series or later truck flywheel. The 12 volt flywheel has 168 teeth, and the teeth are the wrong pitch and depth to work with a 6V starter. Running 12 volts against a 6V starter is no problem, but if you have a key start system it's better to run a 12V solenoid on the 6V starter. Jerry Jerry
| | | | | Joined: Dec 2010 Posts: 13 New Guy | | New Guy Joined: Dec 2010 Posts: 13 | Thank you, that definitely clears it up. I better get my glasses out to count all those teeth to verify which one is on there. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Jerry meant 168 teeth on 12 volt flywheel.
