| | | Forums66 Topics128,049 Posts1,055,695 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | For you warriors - a fellow had one of these at our local swap meet this weekend. It was all polished up, guessing mostly aluminum, some stainless. Would be perfect for a man cave or in your living room if so inclined. Very comfortable to boot. No recline feature however !
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Make sure the thrusters are removed and/or disabled!
The Martin-Baker ejection seat on the F-4 had a rocket pack to allow ground level, zero speed ejections. A maintenance troop at Korat Thailand managed to get the seat rockets lit on a plane inside the hangar shortly before I got there. It BBQ'ed the poor guy, and then ripped the seat mounts loose and put him and the seat through a metal roof. He didn't survive the incident! Jerry
| | | | | Joined: Jan 2011 Posts: 188 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 188 | Better yet, take the all the stuff off that had any type of explosive or propellant off of the seat before bringing it anywhere near indoors. I've never been really worried about ESD (electro static discharge) except when I was working on ejection seats or other types of explosives. Like HRL said, the seats are made for zero/zero ejections these days. Meaning that they are capable of lifting a 250 lb man quite a ways up from 0 feet up and 0 MPH. Even after everything is 'spent', there's usually some residue that can be lit off from one of those explosives. | | | | | Joined: Aug 2001 Posts: 3,595 Moderator | | Moderator Joined: Aug 2001 Posts: 3,595 | 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | |
