9 members (lumbersawyer, sparky46, LAROKE, Otto Skorzeny, Gdads51, Woogeroo, Shade Baby, 68ironhead, Jon G),
143
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,104 Posts1,056,197 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 64 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 64 | I'm thinking I want power door locks and I know many have done power windows but I could really use some help on the best way to get power between the door and A pillar. I read somewhere the pin type contacts are not very reliable. Any thoughts would be great and pics would be even better. Ken
1951/54 Basketcase | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Many of us have both power windows and either "'door poppers" or door locks in their rides. A number of aftermarket companies sell different styles of hoses or conduits to get power and control voltages to the doors. They will require drilling a hole in both the a pillar and door face. The question one needs to address early on is how to get in the car in case of battery failure. Depending on what type of ride you drive, it can be a problem.
| | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | Try installing an insulated positive battery cable connection that's accessible from under one of the bumpers- - - -just someplace to clip a jumper cable in case of a dead battery. The ground cable can connect anywhere on the frame. That would also come in handy for jump starting without the risk of getting a spark near the battery and an unintended fireworks display!
Inside those flexible conduits between the pillar and the door, it's also a good idea to use high-flex wire like the type used for voltmeter test leads, etc. to prevent metal fatigue and open circuits under the insulation from metal fatigue caused by opening and closing the door repeatedly. It's easy to find in all gauges and lengths on Ebay. Jerry
| | | | | Joined: Jul 2015 Posts: 64 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 64 | Thanks guys for the tips. I will still have the key entry on the pass side so getting locked out will not be an issue. Good quality wire is a must I agree. After putting a chunk of plumbers putty in the door jam to get the clearance measure 3/8" and the fact that at least on my doors the hinge area is more of a sideways sliding action. I'm not sure using the conduit kit I ordered would ever work. The two surfaces would have to hinge like a standard door. I think I have got it whipped although it's not the most high tech install I ever saw. I might even be driving this thing for the first time ever by the end of the month.
