0 members (), 119 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
#1217996 05/20/2017 7:11 PM
http://s139.photobucket.com/user/tommyleea/library/52%20Chevy%20Truck
Do two of the tranny bolts come in from the front side, and screw into the tranny? 52 1/2 ton 3 speed.
Step 11 refers to two top cap-screws (bolts) that are removed towards the rear.
Step 12 refers to the two lower cap-screws (bolts) that are from inside the bottom of the clutch housing.
The two guide pins are simply bolts with their heads cut off. These are invaluable for your safety, and the safety of the transmission, and the safety of the clutch/pressure-plate.
If you do not have a hard-copy Shop Manual, bookmark the Shop Manual shown at the links above.
Thanks for the info. I do have a shop manual for the 1854, it is probably the same. I don't know why I didn't remember having it. Thanks again.
1954, probably?
This 48-51 manual will work pretty well (better) for 1952/53.
Good luck, and keep posting questions.
