1 members (UtahYork), 80 guests, and 2 robots.
Topics128,049
Posts1,055,637
Hi, I'm trying to get my motor running !!! Thats a PUN. Actually, I am tryin, but having no luck. When I got this '55 GMC 250 last year, it needesd a little work. Thats another PUN, cause it needed alota work but thats why I got it. ANYHOW, it had a late model electronic dist stuck in the hole but nothing was hooked up. The original was in the cab so I took it apart, cleaned it and put it back where it belongs. Got new points/cond/rotor/cap/wires from NAPA but somethings wrong?? The cap wont fit right. Seems the rotor is too tall? and the cap doesnt fit the housing right ???I took it back to NAPA but it IS the right one?? I'm wonderin, is there supposed to be a cup type points cover that goes under the rotor?? I'm hoping so as that would explain things. Gettin kinda frustrated cause the head is now done, carbs rebuilt, everythings buttoned back up but I cant start it till I get this figured out. Any ideas ??????? Thanx in advance
There is a tall cap and a short cap. Make sure you have the right one for your distributor.🛠 BTW, this question should have been asked in the Engine Forum in a new topic post started by you. Multiple posts of the same question in several forums is poor site etiquette.
#1217798 05/19/2017 12:03 AM
Anyone explain if there is, and what the difference might be, in dist caps for the GMC 270cid motor? If there is actually more than one type, where can one purchace them? Thanx
ODSS Lawman
ODSS Lawman
There is also a matching tall or short rotor. Make sure you have both of the correct type, otherwise you will have not spark
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
My distributors part no. 1112369 shows coming from the original 248 / 270 cid 1952 motor. I went to my local APS told them that number and got cap, rotor, condenser and points to match without a problem. Does your dizzy still have its part no, tag on it?
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
