8 members (Steveoreno, 4tttt8, Waveski, Joe H, RdsLessTaken, greenie-reddy, 78buckshot, 1 invisible),
60
Mod | | | Forums66 Topics128,180 Posts1,057,164 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,844 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,844 | Is there a chart showing PPG's numbers that are equivilant to AD truck color (interior and Ext)?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jan 2002 Posts: 2,844 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,844 | Sorry for posting what I just found by doing a search. Forester green seems to be PPG's 40519
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | We probably need a tech tip detailing just that. Maybe I will work on it.
For the original interior color, I suggest using Chevy Duty's product. I do not have a color code for it. Or at least one I consider a good match. A buddy of mine took a sample of the CD paint to a paint dealer and had it scanned, but the result was not a match in my eyes. | | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | cmayna, do you have the link?? | | | | | Joined: Jan 2002 Posts: 2,844 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,844 | I found the number in a previous post, but check out this site that I stumbled across............. http://www.ppgcarpaint.com/paints-bymake.php?Year=1950&AutoMakerId=52&ModelId=52
| | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | | | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | TCLEADERMAN, When you do your tech tip could you include the OEM numbers so the conversion would be easier. Thanks
Still trying to get ole Betsy back on the road.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Craig,
Good suggestion. I will have to check to see what RPO numbers I have. Is the RPO number/code what you are referring to?
Examples:
1949 RPO 234-H Windsor Blue RPO 234-K Sun Beige
1954 RPO 234P Transport Blue RPO 234R Coppertone
It might also be nice to add the wheel/body stripe color names and paint codes (not all were also exterior colors).
I do not have Truck Data Books or Restoration Pack Specification manuals with RPO codes for most years (I have 1949, 1950, 1953, 1954, 1955-1st). If anyone sends me the year, color names, and RPO codes for other years, I will add them to the paint codes (and reference the person's name in the Tech Tip).
Thanks, Tim | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hey, TC, what ever happened to that list, I still can't access it from either one of my confusers? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That will do it TC, thanks a bunch for posting those. That’s a real asset for the forum. I’m going to download them and burn them to a CD so they will be permanently part of my library. I don’t belong to VCCA but if there is anyone out there that does, do they have something similar at their site? As nit picky as they are, I’m sure that this subject is discussed on a day-to-day basis. Still a few gaps open when it comes to the interior colors on the early ones. And what kind of luck would one have modern day, at a paint dealer converting the three manufacturers paint numbers to today’s formula? Thanks again TC. Denny Graham Sandwich, IL
| | | | | Joined: May 2006 Posts: 166 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 166 | I have a 51 and understand that the interior color was the same for all through 53? I didn't see it listed on that chart. Otherwise it is a great compilation. I was told this when I asked the question in another section.
"Here'the PPG colors: PPG DDL3613 or DCC5558. One is a single stage and the other a two-stage." | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Todd,
Do you know what the original PPG and/or Dupont codes were for those interior colors? The only documented interior colors that I have in the Tech Tip are for 1949, 1953, and 1954/55.
In answer to Denny's question above, PPG can provide modern codes (called offsets) for most of the old colors/codes. Information on how to obtain the modern PPG codes/offsets is provided at the bottom of the Tech Tip.
Tim | | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | tclederman, Hold off on Todd's quote for PPG #'s. I'm trying to get clarification. I'm the one responsible for those from an earlier thread. But I do believe I got those directly from Bob Alder a while back. But after seeing the paint on my interior, i'm VERY scheptic(sp)!!!! The color is a dark copper brown with metal flake. I've got this questions in various spots in the forum so should get an answer soon. I'd post pictures here but do not know how. If someones sends me their email address, I can send the pics to them and they can post it. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Rattletrap 52,
You do not have an email address in your profile. If you want to send me photos, I will post them (my email address is in my profile).
Do you know (or does anyone else reading this know) the original name of the interior color(s)? Any chance it was "Medium Tan Metalli-Chrome" and/or "Dark Tan Metalli-Chrome"? Or, was the original name of the color "Sheen Gray (Metallic) Poly"?
Tim | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: May 2006 Posts: 166 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 166 | I posted in the interior forum a new thread. It has a link to my collection of interior pictures. | | |
