1 members (Bucker),
144
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Do any forum members except me have '34-'36 vintage trucks or pickups? Mine is a '36 Chevy high cab pickup that I've had since 1965.
Ray
| | | | | Joined: Mar 2003 Posts: 315 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 315 | I have a 36 GMC low cab, have had it for about 14 years. | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Good morning Dunfire. I think you and I have swapped emails before but I can't find your email address. After a 40+ year search I finally found a '34-'36 Chevy/GMC truck upper fan shroud 1/2 to complete the fan shroud for my '36. You might find it interesting to see what it looks like installed.
This forum seems to have mostly 1950s era trucks from rural areas. The rural part is not surprising because most city dwellers don't have room to store big trucks.
Even though I've had my '36 since 1965 I'm still finding little projects to do on it. The fan shroud is an example. Another example is replacing the lower radiator hose metal elbow. I just found an inexpensive source for that elbow in stainless steel that will prevent the unsightly rust from coming back.
It would also be nice to find a gas tank with no leaks or dents but as my wife says "People in hell want ice water". I'll probably end up making a gas tank.
Ray
| | | | | Joined: Oct 2015 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 26 | I have a '35 1.5 ton. I haven't done anything with it, it's been sitting in the shed for too many years. It was the first large truck I drove some 45 or more years ago.
1935 QD 1.5 ton stake bed 1937 SD 1.5 ton stake bed 1944 MS 1.5 ton stake bed 1946 PW 2 ton stake bed
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | We have a 36 Chevy 1 1/2 ton fuel truck. We restored it a few years ago. It has won many trophys. It will be in the NTHS show next month in Iowa. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Hi Ray! As you know, I have a 1935 pickup. I have most of the back woodwork done now and I am starting on the floor and pillars. I have been keeping my eye out for a gas tank for you, no luck. Lots of plastic ones and some metal ones that do not look anything like and original. Good luck with the gas tank and the ice water! | | | | | Joined: May 2014 Posts: 23 New Guy | | New Guy Joined: May 2014 Posts: 23 | I found and rescued a 35, just cab and forward last month, the metal is solid, but no wood anymore. I'll be building a frame and running c4 corvette running gear under a mostly stock appearing truck. 1935 Chevy as found | | | | | Joined: May 2010 Posts: 42 'Bolter | | 'Bolter Joined: May 2010 Posts: 42 | I have two '36 trucks, both 1/2T low-cabs. A '36 GMC T14 cab I'm working on now, and a '36 Chevy to build in the future. I really like '36's !!
Daryl
| | | | | Joined: Nov 2011 Posts: 141 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 141 | I have a stock original 37 T-14 daily driver, survivor. Engine has never been rebuilt.
Trombones Totem Poles And Old Trucks!
