1 members (UtahYork),
215
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | I bought a rebuilt carburetor from Classic Parts of America and had a question on a hole that was not in my original carburetor. It is shown in this image: http://s1285.photobucket.com/user/1...20of%20America/Carb_zps14mskaz7.jpg.htmlIs this hole in any of the carburetors from the factory? Any idea why it would have been added? Will the carburetor function with this hole? I don't like the idea of having that big of a hole open to the fuel bowl. Should I return this gem and try somewhere else? Fittings are damaged where someone removed or installed with a pair of pliers instead of a wrench, it looks like they use double gaskets to compensate for the warped bowl instead of properly heading it in a fixture to bend it back, screws are excessively long, spray paint finish is not great with rust showing through on the linkage.
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Send it back.
Where did you buy that from? Jeffrey | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | I would file a complaint with who you bought it from, but since that company does not rebuild carbs, find out who rebuilt that one for them and hunt him down and throw that carb through the biggest window in his single-wide trailer, them calmly walk away without letting him know why.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | FYI, the hole is correct for some years.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dave,
Was there a purpose for the hole?
| | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | The hole is a vent for the float chamber, but that carb has enough other issues I'm surprised Classic would ship something like that. The double gasket will interfere with the high speed mixture. (The carb will run rich) since it places the float and needle valve in the wrong position to work with the geometry of the drilled passages between the float chamber and the venturi. Return it for credit, and find some other supplier. Be sure to tell them why you're shopping elsewhere. Jerry
