| | | Forums66 Topics128,197 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2017 Posts: 5 New Guy | | New Guy Joined: May 2017 Posts: 5 | Does anyone know where I can purchase motor mounts for a 235 cu in engine going into a 1951 3600 pickup? | | | | | Joined: Aug 2012 Posts: 131 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 131 | Is your front mounting plate drilled for bolts? If not they can be drilled. Locations in the Tech Tips http://www.stovebolt.com/techtips/motormount_235.htmlDo you have any of the parts from your 1951 engine? Tech Tips on parts in the assembly. http://www.stovebolt.com/techtips/engines/motor_mount_front/index.htmlRear motor mounts as Im sure you know are on the bellhousing and all of the vendors have replacements Ebay has several listings for complete front mount setups including the front mounting plate, and the hard parts between it and the frame. All of the vendors have the rubber insert
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Clifton,
You might want to ID the year and origin-vehicle for your 235 carburetor. There were significant differences between 1941 & 1962.
| | | | | Joined: May 2017 Posts: 5 New Guy | | New Guy Joined: May 2017 Posts: 5 | I have the complete '51 216 engine but it has a crack the complete length of the block. | | |
