6 members (DadsFirstPickup, John Dlugos, Steelonsteel, fonz8261, MNSmith, Jon G), 101 guests, and 6 robots.
Topics128,120
Posts1,056,321
Members48,439
I'm putting the hood together after paint and have a question about how the handles are attached. I have what I think is the correct nut. It takes a 5/8 wrench and is thinner than normal, more like a jam nut. Does that sound correct? And does it use a flat or lock washer? The reason I ask is that with the movement of the mechanism, it looks like it would work itself loose. Anyway, thought I'd run it by the brain trust.
Dennis
40 Chevy 1/2 ton
Not being real sure how it should be, here is what I did. I used a very thin flat washer and a nylok jam nut. Perfect height and no worries about it loosening. I also have some thin clear Teflon tubing that I cut, flattened, then made a washer to fit under the handle to help protect the paint from the handle when it turns. On to the next...
Dennis
40 Chevy 1/2 ton
I like the rubber washer idea.....thanks
Dan
