| | | Forums66 Topics128,193 Posts1,057,253 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 37 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 37 | My engine lunges when starting out in first gear. It does not make any difference cold or warm. It runs great going down the road, but when starting out it really jerks, or if I slow down then shift into second and start out it lunges also. My neck can't take it anymore! Could this be a carb problem? The carburetor has been rebuilt, but the base shaft has a lot of play and tends to leak. I have checked the normal things such as points, plugs, timing , etc. Also, this engine only takes 4 quarts of oil. It does not have a filter. Is this normal? | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | Sounds like you might have a slipping clutch. When you require torque to gain momentum to start out or to build speed, the clutch might be slipping which causes lurching. You won't feel it when it is running at speed because less torque is required to maintain momentum than to build momentum and the clutch is probably holding under those conditions.
Matt | | | | | Joined: Oct 2016 Posts: 37 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 37 | Thanks Matt!! When I put the engine in I put a new clutch, pressure plate, and throw out bearing in. I also had the fly wheel resurfaced. There is about 5 inches of play in the pedal. Do you think taking out some of that play will help the situation? Thanks again for responding so quickly. Bob | | | | | Joined: Oct 2016 Posts: 37 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 37 | Thanks! I will give it a try. | | |
