8 members (Otto Skorzeny, Paul Mullen, Joe H, 55shaker, greenie-reddy, Steveoreno, Bill Hanlon, KEVINSKI),
83
Mod | | | Forums66 Topics128,188 Posts1,057,330 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 283 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 283 | Could someone provide pictures of the mounting points for the front grill. The pictures should be from a 1958 or 59, Stepside or Fleetside?
Thank you
| | | | | Joined: Oct 2008 Posts: 283 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 283 | There is some info in there, however, I was unable to find the details, that would help me mount the grill. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | are you looking for dimensions or just the general area where they are? Also, the holes in the grill, or the holes in the panel behind the grill?
I probably have an extra grill around, but not sure how that would help if you are looking for how to mount it. | | | | | Joined: Oct 2008 Posts: 283 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 283 | are you looking for dimensions or just the general area where they are? Also, the holes in the grill, or the holes in the panel behind the grill?
I probably have an extra grill around, but not sure how that would help if you are looking for how to mount it. I am trying to understand how it mounts. I would would like the grill and the mounting points on the other side. I have a grill, not sure of the attachment points.
| | | | | Joined: Oct 2008 Posts: 283 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 283 | Help!, Please.
How does the grill mount to the grill support? The grill has no holes that line up with the grill support holes, anywhere. The grill support is original(58), the grill is after market. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no peektures, but there are 2 brackets on the back of the grill, spot weld attached roughly at each end of the lettering that will line up with the pair of holes on each side of the grill support rad opening .... likely those brackets will not have been included with a repro grill
| | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 | I've got a grill for a GMC if that is what you need pictures of? | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | | | |
