0 members (), 102 guests, and 3 robots.
Topics128,186
Posts1,057,319
Members48,469
#1216428 05/08/2017 12:26 PM
Could someone provide pictures of the mounting points for the front grill. The pictures should be from a 1958 or 59, Stepside or Fleetside?
Thank you
You should be able to find the detail in this link--
http://www.trifive.com/55-59Assy.pdf
Matt
There is some info in there, however, I was unable to find the details, that would help me mount the grill.
Big Bolt Forum Moderator
are you looking for dimensions or just the general area where they are? Also, the holes in the grill, or the holes in the panel behind the grill?
I probably have an extra grill around, but not sure how that would help if you are looking for how to mount it.
Mike
I am trying to understand how it mounts. I would would like the grill and the mounting points on the other side. I have a grill, not sure of the attachment points.
Help!, Please.
How does the grill mount to the grill support? The grill has no holes that line up with the grill support holes, anywhere. The grill support is original(58), the grill is after market.
no peektures, but there are 2 brackets on the back of the grill, spot weld attached roughly at each end of the lettering that will line up with the pair of holes on each side of the grill support rad opening .... likely those brackets will not have been included with a repro grill
I've got a grill for a GMC if that is what you need pictures of?
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
Mike
