| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I'm putting the hood together after paint and have a question about how the handles are attached. I have what I think is the correct nut. It takes a 5/8 wrench and is thinner than normal, more like a jam nut. Does that sound correct? And does it use a flat or lock washer? The reason I ask is that with the movement of the mechanism, it looks like it would work itself loose. Anyway, thought I'd run it by the brain trust.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Not being real sure how it should be, here is what I did. I used a very thin flat washer and a nylok jam nut. Perfect height and no worries about it loosening. I also have some thin clear Teflon tubing that I cut, flattened, then made a washer to fit under the handle to help protect the paint from the handle when it turns. On to the next...
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I like the rubber washer idea.....thanks Dan | | |
