| | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Is there a L/R headlight or are they interchangeable? I have one I an going to sell and wanted to describe it correctly. Harold
Harold Is a restoration ever finished? | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Pretty sure there is alert and right | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | I agree. I can check in the morning, if needed. I have two sets, one to use and one other. | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Yes, there is a L & R Headlight assembly for 1941-46 COMM., UTIL.(exc. COE); Group 2.725 L = p/n 925203 R = p/n 925204 Mike B  | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Mike, Any marking on the light itself? Harold
Harold Is a restoration ever finished? | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Harold I emailed you some photos that might help Looking at my spare set, I found this info. No part number was found. The headlight buckets have a mounting bracket on the bottom forward end. The bracket is fastened higher, a little further aft on the outboard side corresponding to which fender it fits. Higher on right, the bucket fits the right fender, etc..
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Lee, The photo tells the story. Thanks, Harold
