2 members (moparguy, MikeE), 60 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#1216452 05/08/2017 3:14 PM
After I finally deciding on what tires to by for the rear of my 49 I bought the tires and took them to a local tire shop. Ask them to mount them to put the new ones on and balance them. After all was said and done it cost me $53.00 and change to get them mounted and balanced. Am I wrong or does this seem kinda high?
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
Red 49 Truck #1216457 05/08/2017 3:24 PM
Yep, in my opinion what they charged you was a little high. Just had a new spare mounted and balanced, already had a new valve stem. All said and done with tax I was charged $19.00 at a Goodyear tire operated franchise.
Tim
1970 VW Beetle
fixit1958 #1216461 05/08/2017 3:38 PM
I thought that was high. Maybe they were mad because I didn't buy the tires from them. They didn't have what I wanted. Lesson learned. Ask before you get things done!!!!
Red 49 Truck #1216476 05/08/2017 5:11 PM
It's called the don't ever come back unless you buy your tires from us fee. Never could understand why the tire shops got mad when you try to spend money.
Red 49 Truck #1216502 05/08/2017 9:41 PM
2 Offline
I work at a tire shop with a good reputation in the area. $53.00 is probably on the very high end but not way out of line. It just depends on the area and shop. We would be around $40-45.00 for 2 tires out the door if you supply your own tires. If you buy them from us the mounting is free.
I'm sure they aren't mad or don't want your business again. Keep in mind it is a business giving stuff away free doesn't pay the bills. labor time, weights, stems, tire disposal, and tax all cost money. It adds up quick. Being a regular customer or just some random guy off the street can make a difference too.
I would call or ask around next time. if you can get quality work done at a cheaper price go for it.
Richard
42 Chevy pickup
65 Chevy C10 Panel
Red 49 Truck #1216506 05/08/2017 9:50 PM
Very good post, 2manyprojects.
I would have been OK with $25-$30 for mounting and balancing two tires, plus the cost of inner-tubes/stems, but I would not be upset at the cost in the first post if it was for simply mounting 2 tires (nonetheless, . . . beggars can't be choosers . . . ).
Red 49 Truck #1216516 05/09/2017 12:02 AM
Some of these tire chain stores reward managers for the amount of service $$$ written, just like they do with service writers at dealerships.... and all it does is create a centrifuge for lying and bilking people out their money. And they do it with a smile.
The last tire chain store I went to to get an alignment on my '63 GMC after replacing all the ball joints and tie rods, gave me a $85 estimate, then called me in the middle of the job and told me that they would have to order a $245.00 "shim kit" to get it aligned properly. What transpired after that phone call I won't go into here, but if they are doing it to me, they must be doing it to thousands of others.... a sad state of affairs indeed.
~ Dave
Red 49 Truck #1216540 05/09/2017 2:35 AM
$20-$25 a tire around here. (Virginia.)
Red 49 Truck #1216551 05/09/2017 3:17 AM
$53 to mount and balance 4 tire is actually low, you got a good deal if they did it that cheap. The industry average is around $20 per tire to mount them, plus around $4-$5 for stems. The cost of labor and materials has gone up, especially since the EPA outlawed lead wheel weights and require the use of more expensive steel weights.
Bill Burmeister
Red 49 Truck #1216570 05/09/2017 5:05 AM
Quote
Read the first post again. It was 2 tires, not 4.
Harold
Harold
Harold46 #1216674 05/10/2017 1:39 AM
Harold
I missed that part. Still, $53 isn't that bad, that's $26.50 a tire, pretty much within the industry standards these days.
Bill Burmeister
Red 49 Truck #1216768 05/10/2017 9:52 PM
So, I guess getting four 15" tubeless tires (that I provided) mounted and balanced and installed on my trailer for $50.00 was a bargain! That included new bolt-in valve stems, also. I'll definitely be doing more business with that shop and recommending that others do business there.
When I ran a 24-hour truck shop and road service, I found that referrals from satisfied customers brought in far more dollars than trying to rob everyone who came through the door did!
Harold46 #1216829 05/11/2017 12:55 PM
Bright, it was two tires. Maybe I have been out of the picture to long. It cost me 1200.00 for the tire on my Z71 a year or so back. I almost had a heart attack on that one but at least I knew ahead of time. It's my fault, I should have asked first but I had no idea that things have went up so much. I live in the country a don't go shopping and stuff like that so I'm kinda out of touch.
Red 49 Truck #1216831 05/11/2017 1:02 PM
That's Right not Bright.
