2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Has anyone tried the Krylon "Fusion" brand rattlecan paint for plastics? How about on restored steering wheels? Comments? | | | | | Joined: Aug 2006 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 26 | I used the black on the dash and inserts on my Toyota truck last year. It still looks great, even with the intense heat that it sees in the cab and the temp swings due to my cold a/c. I wiped everything down with prep rags and put 3-4 light coats on everything.
I have no peeling, scratches, or chips anywhere. | | | | | Joined: Jul 2002 Posts: 59 Member | | Member Joined: Jul 2002 Posts: 59 | I haven't used Fusion but I have used a product called SEM when I restored my plastic door panels and it's held up well for nearly 4 years now. It may be available locally but I purchased from yourautotrim.com . I also used SEM Vinyl Prep before I painted. The stuff's not cheap but I've been very please with it. 72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
| | | | | Joined: Apr 2006 Posts: 53 Member | | Member Joined: Apr 2006 Posts: 53 | For refinishing older steering wheels up to '72 Duplicolor gloss or semi gloss lacquer works great. It adheres to plastic very weell and won't chip or rub off. Just make sure all grease oil etc. is wiped off I use lacquer thinner right before spraying. | | |
