| | | Forums66 Topics128,204 Posts1,057,297 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2017 Posts: 11 New Guy | | New Guy Joined: May 2017 Posts: 11 | How do we identify what wheels are on truck? We have a 69 C60 with tag axle. And looking from outside they appear to be 5 spoke. How do I figure out exactly what wheel we have?
New to site and just surfing forums it appears there are safety issues with the widow maker. | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | If they are spoke type wheels, they are not R-H5°. There are various lock ring type open center wheels available and tubeless drop center wheels are also available. Does the entire truck have open center wheels or just the tag axle? | | | | | Joined: May 2017 Posts: 11 New Guy | | New Guy Joined: May 2017 Posts: 11 | We've only had the truck a few months and I think the spokes are all the way around. We've never had a big truck before so I just glanced at them and the tires. All looked like new. Never new there were issues like "widow maker" until I joined Stovebolt a couple days ago. I've been researching brake upgrades and while surfing forums ran across wheel issue. The truck is at our farm about a 100 miles from here so next time we go over I was going to really look at all wheels. Just wasn't sure what to look for that's why I posed question.
There are various lock ring type open center wheels available and tubeless drop center wheels are also available. Not sure what this comment means. Thanks
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: May 2017 Posts: 11 New Guy | | New Guy Joined: May 2017 Posts: 11 | Thought that was geared more towards the 48-53 when I first read it. After more reading it appears the Daytons are fairly safe. Tire availability and looks might be to reasons to upgrade. This C60 will basically be going back and forth 3 miles hauling wheat to silo on a gravel road. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Any sort of round wheel that stays round should do the trick then. | | | | | Joined: Feb 2004 Posts: 29,879 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,879 | This C60 will basically be going back and forth 3 miles hauling wheat to silo on a gravel road. Buy a set of Chinese-made tube type bias ply tires, the same size as the ones that are on it now. They should last 20-something years at least, and the sidewalls will dry rot long before the tread wears out. You probably won't even get them warm enough to iron out the flat spots that develop from being parked for a few days at a time. Jerry
| | | | | Joined: Nov 1995 Posts: 5,744 24601 | | 24601 Joined: Nov 1995 Posts: 5,744 | Going back to the original question about identifying what you currently have on the truck, maybe it would be helpful if we could see a picture of the truck showing the wheels and tires, and then a closeup of one of the tires and wheels, plus any of the information on the sidewall of the tire (specifically it will read something like "10.00 x 20 ") Tell us what those numbers are. Once we know for sure what you actually have, we can be more helpful with making recommendations. Welcome to Big Truck Land!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: May 2017 Posts: 11 New Guy | | New Guy Joined: May 2017 Posts: 11 | Plan on going over next week and getting some pictures to post. Trucks in great shape except for a couple cancer spots about 6" below windshield corners on both sides. Had tag axle hydraulic cylinder rebuilt and planning on installing it. When there will take pictures of tires/wheels. Wasn't sure if there were any numbers stamped into wheels and that was what I was thinking in my original post. | | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 |
1950 4100 - unrestored and driven weekly for almost no reason at all.
