1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
So, school me a little on the advance design series as far as core supports go. I have a 2 ton, and it looks like the 47-49 trucks use the same core support mounting as my 2 ton.
http://www.classicparts.com/1947-49-Radiator-Support-Mounting-Pad/productinfo/78%2D621/#.WQT4-cYkphE
I bought a ragged out 48 1 ton for the bed, and it has the same close two bolt pattern for the core support as my '52 6400. Thoughts? Any conflicting info out there?
Liquidated my projects
Now looking for a decent '47-'55.1 3100, 3600, or 3800
All I know is that my '50 3/4 ton has the same close two-hole mount, but the book says it's supposed to have the other stye mount.
Not sure what do you want to know, exactly- If you know which mount you have, then you know which pads to order, right?
~ Dave
I was just wondering if the advance design trucks all started out using the close center 2 hole mount, and the smaller trucks switched over at some point while the big bolts stayed with the old style.
