| | | Forums66 Topics128,026 Posts1,055,403 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2016 Posts: 80 'Bolter | | 'Bolter Joined: Dec 2016 Posts: 80 | Engine ID by the distributor reads FII21J Flint plant, January 21, Truck engine? How do yo know the year? Guessing I need a more info?
1959 3204 Basic Cab
| | | | | Joined: Dec 2016 Posts: 80 'Bolter | | 'Bolter Joined: Dec 2016 Posts: 80 | Date codes on both the block and head are K208. So, November 20 1958 and like you said the serial code indicates Flint engine plant and that it is a truck engine. Sure gives me hope this is the original engine with the truck. Thanks for your help!
1959 3204 Basic Cab
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | A Nov engine usually indicates it was put in a 1959 truck.
1959 3100 Apache Fleetside
