5 members (Jon G, Hotrod Lincoln, Still At It, Otto Skorzeny, Uncles51), 81 guests, and 1 robot.
Topics128,022
Posts1,055,386
Members48,422
#1215954 05/04/2017 4:35 AM
Engine ID by the distributor reads FII21J
Flint plant, January 21, Truck engine?
How do yo know the year? Guessing I need a more info?
1959 3204 Basic Cab
Wrencher88 #1215968 05/04/2017 11:51 AM
Past the head and block date casting codes, to determine the year(s) of casting.
Your code's format has no year information - it was used from 1958-1962.
The J designates 3100-3800 truck.
tclederman #1216061 05/05/2017 4:45 AM
Date codes on both the block and head are K208. So, November 20 1958 and like you said the serial code indicates Flint engine plant and that it is a truck engine. Sure gives me hope this is the original engine with the truck. Thanks for your help!
1959 3204 Basic Cab
Wrencher88 #1216067 05/05/2017 7:02 AM
A Nov engine usually indicates it was put in a 1959 truck.
1959 3100 Apache Fleetside
