1 members (Hotrod Lincoln),
327
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | I seem to never be able to get filler mixed correctly. I usually mix up a glob about 1/2 the size of my fist, then squirt about 3/4" line on it from the tube of hardener.
I worry, I either get too much or too little. Do you guys have a better way?
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
| | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | Michae1964, As you get to using it more and more, all this will come to You...If You have a large area to put bondo in, then that means you don't want it to kick off before You get Your full area covered....The less hardner you put in, the longer it will stay workable and will be stronger also...the most important part of mixing is make sure You have it mixed real well...You will also find hardener fresh off the shelf that is gritty. It has a shelf life, don't use it, make them give You a new tube.... Bondo 1/2 as big as Your fist should get approximately 3/4 " ribbon of hardener. Bill B | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | Michael, almost forgot....always make sure You kneed the hardener with the cap on cuz if You don't when the lid comes off oil that has seperated will squirt out...Must blend it all together...Bill B | | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 |
| | | | | Joined: May 2006 Posts: 35 Junior Member | | Junior Member Joined: May 2006 Posts: 35 | if i'm using bondo i try to use the spreaders that are color coded to match the correct, mixed, color of the filler.
and as bill_b says above, i prefer slightly paler for better workability and strength.
bill graham
| | | | | Joined: Dec 2002 Posts: 39 Member | | Member Joined: Dec 2002 Posts: 39 | whats with bogging the hole vehicle and then start and sand it of on Boyd Coddington is this what all body men are doing or what? | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Originally posted by dgrahams: if i'm using bondo i try to use the spreaders that are color coded to match the correct, mixed, color of the filler. I have never known this existed, what a great idea. I seem to remember seeing a pale pinkish spreader that would be the same color as some fillers when mixed with a red hardener, that is a GREAT idea. Brian
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Jan 2007 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 48 | The pink color coded spreaders I have seen locally are Bondo brand. They are sold in a bubble carded package.
Joe -------------------------- '67 Chevy C20 fleetside, 250 inline, 3 on tree, heavy duty clutch and brakes, heater, steel bed floor ----------- "Tighten until the stud snaps, then back off half a turn."
| | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | One trick I learned is to take your round blob of filler and cut it in half with your spreader, now two blobs = 50% of total, cut one in half again = 25%, again = 12.5%, again = approximately 6%, again is 3%, match your hardener amount to that last pile, or slightly less; that is to say 2-3% hardener to filler. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You also would ant to avout mixing too much up in one shot. When mixed properly, it'll "kick" within about 3 minuits, and unless you work fast, you end up with a half solidified glob of filler that's no good. I usually won't mix up more than about 1-2 tablespoons at a time. If I need more, I'll let what i put on set, then add as necessary. Another tip is to keep from getting air in it as you mix. Getting air in it causes bubbles and voids in the filler that you will have to fix later. One more thing. Not to put down Bondo, as it is a good product, but I personally prefer to spend a couple of bucks more and get the Dynatron (same company, better product)fillers. They're a professional grade filler, and sand out smoother and easier. They're usually a gold color instead of the normal pink, though Dyna-lite is the standard pink color. Auto-Zone and Advance Auto both have been carrying Dynatron, 'Zone seems to have a better selection, or at least in my area.
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | My filler says to use a 4" strip on a 4" diameter pile of filler. It also says 2-3%, but not how tall the 4" pancake is. I have had to throw out filler because it does get too hard to spread too quickly. Seems like that only takes a few minutes or less to happen. Am I using too much hardner or just mixing up to much filler? I did try about 3 or 3.5" strip and it didn't make much differance. | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | when its hot less harner is needed when working in a cold shop i use more hardner | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | just a tip Michael , find a pc of old plexiglass to mix on dont use cardbaord of anykind to mix on it will suck out the good stuff in the mix and make your bondo not so good . | | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | Kemp...you thin coat the body and sand off to get all straight...doc | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | As you know, when the catalyst kicks in, it gives off heat. That heat causes next-door molecules to kick-off. Pretty soon, the whole thing is cross-linking, going through the reaction to turn solid. Smaller masses (globs of mix) will give off less heat, so the reaction will be a little slower. On the down side, you have to be more precise on your mix ratio.
I'm a poster child for Body Filler Amateur. I know the mechanics of it, but I haven't mastered the knack. Until I do, I'll continue to work with tablespoon-sized mixes on my bumper project. I find when I go golf-ball sized, I end up throwing out about half of it.
Bill | | | | | Joined: Jun 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 191 | | | |
