4 members (Gdads51, dt235sd, baldeagle, Mike Roache), 171 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#1215985 05/04/2017 2:32 PM
If you apply suction to the vacuum advance, should it hold the pressure indefinitely or does it gradually release? I have several of these and want to bench test them.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
If it releases it's bad, although it may work for a while.
If bad it's also a vacuum leak that will raise your idle speed and ruin your idle mixture adjustment.
OK, Thanks.
1946 1-ton Panel
H Online: Content
If there's vacuum on the advance unit at idle, you've done some very, very wrong plumbing from the carburetor. Unless you're able to suck a golf ball through a garden hose and keep it up for quite a while, buy yourself a Mityvac pump and save yourself a bunch of effort. Pump the advance to its full travel, pinch the hose off tight with a pair of smooth-jaw pliers, and see how long it takes for the vacuum to bleed off. Half a minute or more is probably OK- - - - -a few seconds isn't.
Jerry, Are you saying that these engines should be using ported vacuum instead of manifold vacuum? Dave
H Online: Content
That's the way they were designed- - - -no vacuum at idle, a gradual increase in vacuum on the advance unit through part throttle, and almost full vacuum at light throttle cruise speed. As the throttle is opened for passing or hill climbing the vacuum advance goes away to avoid detonation with the power valve open in the carburetor, leaving only centrifugal advance for pulling.
Thanks for the explanation Jerry. Dave
