| | | Forums66 Topics128,154 Posts1,056,861 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 10 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 10 | Burned out 6v fuel gauge when I converted to 12v in my 53 -3100. Installed new 12v gauge and it seems to be stuck at 3/4 tank. Unhooked wires from sending unit and it stays on 3/4. Am I wired wrong? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | "Unhooked wires from sending unit . . .[/b] . . . "
Do you have more than one wire from the tank sending unit to the gauge?
Did the new 12v gauge indicate the ohm rating for the sending unit? | | | | | Joined: Mar 2009 Posts: 10 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 10 | One wire to gauge and one ground. Don't know the ohm rating. New gauge but sending unit was in when it was still 6 v
| | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | You have a bad gauge. What did the new gauge read when you received it. Which post did you wire to ignition switch? Gauges do not like it when you do it backwards. Ignition switch wire goes to the "E" (empty) post. Carl
