0 members (),
119
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 40 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 40 | Hollo and thanks for any information. I have purchased a 54' 235 to replace a 216 in a 40 truck. I've read and searched the forums and tech section. My replacement 235 is front mount. The tech article references a 55' and newer motor. I'm under the impression the 54 will work and be easier (?) to swap. It was purchased from an elderly friend who drag raced 6's back in the day. It is a stock truck motor with everything except the starter. Turns,makes compression, ect. $150 so I should be in a good spot. I'll need to use the 40's bell housing,clutch,pressure plate, but I'm not sure about the flywheel. Some are 9 and others 11 ?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You will need a 1942 or later flywheel to fit a full pressure 235. 1942 started the 7/16" attaching bolt size.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2017 Posts: 40 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 40 | So I can use the 54 flywheel and clutch in the 40 bell housing? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1942-62 flywheels will fit. Some of the larger 1954-62 pressure plates could be a tight fit in the bellhousing. Also remember 6 and 12 volt flywheel teeth are different and can not be interchanged.
