0 members (),
61
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12157 01/02/2004 7:48 PM | Joined: Feb 2003 Posts: 45 Member | | Member Joined: Feb 2003 Posts: 45 | Are front and rear brake cylinders different(size) 1950 1/2 ton . thanks
1950 1/2 ton 3 window
#12158 01/02/2004 8:18 PM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | CMC 1/2 ton truck front cylinders are wagner #F3406 (Casting # FD3407) which are 1 1/4 bore the rear is part #F3396 (Casting # FD3397) which is 1 3/16 bore, brake hose numbers F4497 front& rear. They look the same from the outside | | |
