7 members (Wally / Montana, Gray_Ghost, JW51, Otto Skorzeny, kades51, Bill Hanlon, 1 invisible),
98
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,052 Posts1,055,724 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy whateverpratt, I found mounts at RockAuto. These are Anchor mounts, p/n 2060 is the narrow design mount for the lighter trucks $3.41, p/n 2073 is the wider/heavier design for the larger trucks $4.11, hope that helps. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Could my rear motor mounts from Rock Auto at a great price.
Being the rear mounts bolt to the clutch housing and not the engine so Rock Auto lists the rear motor mounts in the transmission section. Jeffrey
| | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | That's great. I found what I needed. What about the front mount? Does anyone have an anchor number for that one? I'm also looking for a replacement mount for my radiator support.
Liquidated my projects Now looking for a decent '47-'55.1 3100, 3600, or 3800
| | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | Ok, it looks like the front mount is Anchor 2007, but I don't have the hardware for the front mount. Isn't there a metal plate or something?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy whateverpratt, there is a mount plate which bolts to the front of the engine block behind the timing gears, it drops down below the balancer and has a 90 degree bend which the front engine mount bolts to. If you need one of those plates please post an ad in the parts wanted forum farther down the page, hope that helps. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | What we really need to do is to motivate Hotrod Lincoln to come up with a better, simpler design for the front mount. Ohhh Jerrrry...
| | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | I think I found it. This is what I meant about the front plate.
http://www.classicparts.com/1932-54-Front-Motor-Mount-Shield/productinfo/79%2D006/#.WQXnwMYkphE
The website mentions it goes between the engine (the mounting part on the timing cover) and the rubber mount. Does that sound right?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy whateverpratt, there are two pieces on the top side of the rubber if I remember correctly one is just a cover, I think that the cover is what your link goes to. So your engine already has the mount plate mounted to the engine block? | | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | I have an early 216 or 235 timing chain cover with the holes for the mount. I haven't installed it yet, but I plan to
